4
This discussion topic has been answered Discussion topic: WiFi completely down
This message was authored by: Bwilson16
The whole WiFi has gone down. Stating a problem with the router. Online looks like a lot of people experiencing the same issue.
Re: WiFi completely down
If the broadband is still down in the morning use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
This message was authored by: Winw1
Mines the same. Suddenly went down around 40 minutes ago in the middle of a film 😩 Oh well it seems to be a widespread problem so I'll just wait it out and read a book instead... 😁
This message was authored by: Jen1313
Yep same here. But all the Sky service checkers insist there is no issue!!! Infuriating!!!
Yes, my Sky app is saying that everything is up and running fine when it's clearly not 🫤
This happened with my internet last month as well.
If it becomes a regular occurrence then I'll look at changing providers.....!
