Discussion topic: WiFi buffering
Message posted on 09 Sep 2026 09:44 PM
WiFi buffering
just had WiFi 7 installed in my home yesterday the connection seems poor only 2 bars of WiFi when going into a different room to the hub and keeps buffering
Message posted on 09 Sep 2026 10:33 PM
Re: WiFi buffering
A poor signal is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
