Discussion topic: WiFi buffering
Message posted on 16 Apr 2026 07:55 PM
WiFi buffering
WiFi buffering tvs around the house
Message posted on 17 Apr 2026 07:47 AM
Re: WiFi buffering
@Hayley100 streaming TV requires a good steady WiFi connection the fact your's are buffering implies your WiFi is nit up to the task. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
