Discussion topic: WiFi / broadband down
This message was authored by: Mrtnbwmn
 Broadband has just lost connection literally in the last 15 minutes. I have switched everything off and in again but it will not connect to WiFi and broadband
Re: WiFi / broadband down
@Mrtnbwmn
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
