Discussion topic: WiFi/broadband down
Message posted on 22 May 2026 06:05 PM
WiFi/broadband down
Need support to get this up again
Message posted on 22 May 2026 06:22 PM
Re: WiFi/broadband down
@Nicolabaker
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 22 May 2026 06:23 PM
And realistically the Friday evening before a Bank Holiday weekend is always an unfortunate time to be reporting a fault.
