Discussion topic: WiFi booster
Message posted on 01 Dec 2025 06:12 PM
WiFi booster
The engineer who installed the sky tv boxes advised that we need a booster as we have next to no wifi upstairs in our house
Message posted on 01 Dec 2025 06:47 PM
Re: WiFi booster
@Dolly722 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
