Discussion topic: WiFi and tv issuesq
This message was authored by: Scuffer714
WiFi and tv issuesq
WiFi and tv
Both our WiFi and tv have been playing up for the last six days. Even though the system is saying we have no issues our WiFi and tv keep dropping out. My wife works from home so needs to have a stable WiFi connection.
What is happening?
Re: WiFi and tv issuesq
@Scuffer714 Have you run the diagnostic service against your line, and the about lights will get you there!
Try running the line test here to see if any faults are found:
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
