Discussion topic: WiFi and therefore tv not working
This message was authored by: Louise7111
My WiFi is not working so neither is my tv, I have tried resetting both without success
Re: WiFi and therefore tv not working
@Louise7111
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Louise7111
Level 0 icon
Many thanks for your reply, I've tried the home checker and at the third time of repeating the check it is now displaying problems in this area - very frustrating 😡
