2
This discussion topic has been answered Discussion topic: WiFi and internet not working
This message was authored by: DonkeyKong
Despite turning on and off my router and resetting it, my WiFi and internet connection has gone.
no cables have been changed, it has just stopped working.
I need to use it for work too - so would like a call back,
all lights are on in the router, including saying it has interntrt and WiFi but my phone, and computers cannot get WiFi now.
This message was authored by: GD1 Answer
Re: WiFi and internet not working
@DonkeyKong  You won't get a callback from acustomer helps customer community, working from home does not give your service any greater priority
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
@DonkeyKong
No one will / can call you. Your username on the Community isn't linked to any Sky accounts you may have.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
