Discussion topic: WiFi & sky stream
This message was authored by: Dazzle73
WiFi & sky stream
WiFi and Sky stream not working!
Re: WiFi & sky stream
@Dazzle73
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
Avatar for Dazzle73
Yes problem apparently with local broadband, stating to be fixed within 48 hours. That is not good enough, can't use anything and can't use the services I pay for.
@Dazzle73
Sky usually quote 2 WORKING DAYS as a potential fix time due to the service level agreement in the UK between ISPs and Openreach for fixing a fault. Openreach claim to be successful within that timeframe in about 85% of cases.
Some repairs take longer, for example when a pole or cabinet has been damaged or Openreach / City Fibre need to dig the road up (after getting permission from the local council).
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day)
▫️There is no equivalent scheme in place for customers in the Republic of Ireland.
▫️There is no automatic compensation for TV services affected by a broadband problem.
▫️Sky broadband being discussed here is a domestic service therefore whilst it's fine for customers who work from home to use it for that purpose they won't receive additional or quicker support.
Avatar for Dazzle73
No internet
Trouble with local broadband yesterday afternoon till evening. All ok this morning. Come home and have no internet or phone line
Re: No internet
@Dazzle73
As you've already been given the advice yesterday you may need to contact Sky to report this.
