Discussion topic: WiFi access distance / thick walls
This message was authored by: Kophie
I am currently with Virgin and need to use their pods for accessing WiFi at the far side of the house, I'm thinking of going over to Sky but concerned the WiFi will be weak/not accessible for TVs in the upstairs bedrooms. Comments please.
Re: WiFi access distance / thick walls
@Kophie
If you do move to Sky and add Wi-Fi Max to your account then Sky will supplier up to three pods for you to use as you can read about here:
