Discussion topic: WiFi Signal issues to next room and kitchen
This message was authored by: WifiDin
Even after taking Sky WiFi Max hub there is no range in other rooms, pls install the WiFi booster.
Re: WiFi Signal issues to next room and kitchen
@WifiDin you sill have to call Sky to get an extender pod sent out as part of the WiFi Max bundle. However be warned if the internal walls of your home are solid brick or stone the pod could also struggle as it needs a good connection over 5GHz back to the hub. You msybe better buying your own WiFi kit or looking at other technology such as hard wired Ethernet connnections or powerline.
