Discussion topic: WiFi Router
This message was authored by: Wendy-Clubbe62
WiFi Router
My WiFi router is approx 15 years old and continually loses connection  whilst watching TV (poor connection)
Is it possible to have an updated router to see if it helps with this issue?
Re: WiFi Router
@Wendy-Clubbe62 if your printer was supplied by Sky they are in the process of replacing all routers older than roughly 6 years due to new regulations coming in later this year.. Check your email spam filter as you may have an email explaining how to get a replacement already alternatively you can wait for them to contact you which should happen quite soonor call them yourself and ask for a new Sky hub to be sent to you.
Re: WiFi Router
@Wendy-Clubbe62 Also with the age off your router, it has certainly done well and due a rest now, sky should know what equipment that you have, see if the link below will get you as needed.
www.sky.com/skyhuboptions
Avatar for Wendy-Clubbe62
Re: WiFi Router
Thank you for your reply and the link provided. I have contacted Sky and await their reply.  Many thanks for taking the time to help.
