Discussion topic: WiFi Problems
This message was authored by: Richard_12
Message posted on 08 Sep 2026 08:13 AM
WiFi Problems
I installed a new Sky max broadband router yesterday and since then I have had problems connecting devices to the network at the back of the house my mac, phone and TV will not connect because the signal is too weak . This was never a problem with my old router
Find out more
Message posted on 08 Sep 2026 08:57 AM
Re: WiFi Problems
A poor signal is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
