Discussion topic: WiFi Not working
Message posted on 03 Oct 2025 12:53 AM
WiFi Not working
My WiFi is not working why? It is saying there is no problem in my area???
Message posted on 03 Oct 2025 05:22 AM
Re: WiFi Not working
@NatC40
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you are having broadband problems after 7am use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
