Discussion topic: WiFi. Not working
Message posted on 29 Apr 2025 01:55 AM
WiFi. Not working
Wifi has been down for about an hour, and has been down for other users too. Anyone know when sky will fix the services
Message posted on 29 Apr 2025 03:22 AM
Re: WiFi. Not working
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by 0700 use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
