Discussion topic: WiFi Keeps disconnecting
This message was authored by: AdamV1
Hi there,
My WiFi keeps disconnecting. I have run a check using the MySky app and it says everything is okay. Ironically, though, midway through the WiFi disconnected.
The signal often appears very weak with 1 or 2 bars even as I am sitting next to it. The issue is most pronounced on my iMac computer upstairs with it disconnecting every few minutes while I work from home. This is very frustrating since I have only recently joined with you.
I look forward to your response.
Best wishes,
Adam V
This message was authored by: KEB2
Re: WiFi Keeps disconnecting
We are having same issues aswell
@AdamV1 @KEB2
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
