Discussion topic: WiFi Issues
This message was authored by: TC01
WiFi Issues
Hi, for the last 30 mins my wifi has been off. I've checked the hub and the Internet is flashing orange, it stops for maybe a second and then starts again. I've checked my WiFi and broadband through the sky app to which both say it's working.
anyone able to help?
Re: WiFi Issues
@TC01
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
