Discussion topic: WiFi Issue
Message posted on 05 Aug 2025 05:18 PM
WiFi Issue
Hi, I don't have internet and the speed prior to it stopping was very slow. Please help me resolve this. The online test showed no problem for some reason
Message posted on 05 Aug 2025 05:39 PM
Re: WiFi Issue
@Nedka
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
