Discussion topic: WiFi Fault
Message posted on 15 Apr 2025 09:37 PM
WiFi Fault
The WiFi keeps dropping out.
we are having issues on all devices
Message posted on 16 Apr 2025 05:07 AM
Re: WiFi Fault
@Sean63
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
