Discussion topic: WiFi Down
Message posted on 14 Nov 2025 12:16 PM
WiFi Down
Light on box is on, check done here says no issue with connection but wifi isnt working. Box restarted.
location - Hertfordshire
Message posted on 14 Nov 2025 12:29 PM
Re: WiFi Down
@Charlotte53
The current heavy rainfall may be causing broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
