Discussion topic: WiFi Connection
This message was authored by: Brendan43
WiFi Connection
I have WiFi set up in my property - the connection works on the top two floors of my house but does not cover the ground floor adequately. I think I need a broadband booster on the ground floor.  Please advise.  Brendan
Re: WiFi Connection
@Brendan43
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
