Discussion topic: WiFi Connection
Message posted on 23 Nov 2025 04:47 PM
WiFi Connection
I have a poor connection to the wifi in other rooms and to the front door for my ring doorbell. Is there something that can boost this connection
Message posted on 23 Nov 2025 05:15 PM
Re: WiFi Connection
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 23 Nov 2025 05:16 PM
Re: WiFi Connection
@LaraLC The sky information about that is linked below for you to read!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
