Discussion topic: WiFi Connected but no internet
This message was authored by: jamesbo
Hi,
I keep having WiFi issues where my devices say they are connected to the WiFi but there is no internet.
I can use one of those devices to logon to the router and I can see other devices on the LAN and anything connected to the LAN works fine.
The MySky app is a joke and no help, any advice?
Thanks,
James
Re: WiFi Connected but no internet
@jamesbo
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Avatar for jamesbo
Hi,
Reboots fix it for a few days and then it fails again.
The LED stays white, I can access devices on my LAN, just WiFi routing fails.
The logs are always empty, the MySky app only shows this when I select the router and has never worked on tablet or mobile:
