Discussion topic: WiFi Calling
Message posted on 12 May 2025 09:39 AM
WiFi Calling
Hi,
Wi-Fi Calling won't activate when connected to the Sky Hub 4.2 on Full Fibre 500
I have an iPhone 15 Pro on the latest software with a Sky sim and when I connect it to the Sky Hub it deactives Wi-Fi Calling but if i connect it to the eero mesh that I have set up it activates Wi-Fi Calling immediately.
What setting in the Sky Hub needs changing to allow Wi-Fi Calling to activate.
Message posted on 12 May 2025 10:39 AM
Re: WiFi Calling
@Davidlm It is nothing to do with the hub, and there are no settings for you to adjust, this is a phone issue, wi-fi calling works fine and is device and system dependant...
Message posted on 12 May 2025 11:26 AM
Re: WiFi Calling
Thanks for your reply but I have since found another thread where it seems that the hub is the issue and Sky are aware it and working on a resolution.
Message posted on 12 May 2025 12:42 PM
Re: WiFi Calling
@Davidlm No problem, just glad my wi-fi calling is working fine!
