Discussion topic: WiFi Booster Box
Message posted on 15 Apr 2025 08:23 PM
WiFi Booster Box
I got a booster box that was connected to my WiFi hub skyjpk??but I since change my WiFi to WiFi max (so got a new hub) my booster is saying connected but I'm not sure it is, as my new hub is skyclg?? when you go onto WiFi connections I have my hub and my booster box but both on different sky connection names. Does this mean my booster isn't connected to my new hub? Or does that not matter??
Message posted on 15 Apr 2025 10:56 PM
Re: WiFi Booster Box
@StephWills Did you reconnect the SE210 booster to your new Max router?
Message posted on 16 Apr 2025 06:23 AM
@StephWills the old SE210 booster has limited ability to extend wifi from your new hub basically it can only be used to connect Sky Q tv boxes. Sky will supply a pod extender to customers who buy WiFi Max who need one so give them a call. The pod is designed to work with the new hub.
Message posted on 30 Apr 2025 12:41 AM
How do you link them??
Message posted on 30 Apr 2025 12:42 AM
I'll give them a ring. Thank you
