Discussion topic: Wi if will not work
Message posted on 30 Dec 2025 01:05 PM
Wi if will not work
My WiFi has gone down. I've tried all the tips given but it's still not working.
Message posted on 30 Dec 2025 01:17 PM
Re: Wi if will not work
@JBirch
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
