Discussion topic: Wi fi.
Message posted on 05 Jan 2026 11:19 AM
Wi fi.
Message posted on 05 Jan 2026 11:27 AM
Re: Wi fi.
@Stu-82
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
