Discussion topic: Wi-fi
Message posted on 03 Aug 2025 05:48 PM
Wi-fi
Are wi-fi keeps cutting out it's been happening a lot lately , need help as all signal says no problems????.
Message posted on 03 Aug 2025 05:54 PM
Re: Wi-fi
@Kpeachey1
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
