Discussion topic: Wi fi
Message posted on 24 Feb 2025 05:33 AM
Wi fi
My wi fi has been dropping out every minute for the last two days,
it is affecting most appliances in my home as they are wi fi controlled, can you send an engineer to investigate and get by to sort line if there is an issue with the box
Message posted on 24 Feb 2025 05:42 AM
Re: Wi fi
If an engineer is required you'll need to contact Sky. This is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
Re: Wi fi
As this is a customer helps forum we can't send anyone so the try running the line test here:
If this is of no help give Sky a call to report it to them.
