Discussion topic: Wi fi not working.
This message was authored by: Chaz-E
Wi fi not working.
The router has been restarted twice and it still has no internet. I've done the check internet thing on the website and it says it's fine. I'm using 4G to complete this form because there is no internet connection.
Re: Wi fi not working.
@Chaz-E
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
