Discussion topic: Wi-fi issues are rubbish
Message posted on 12 Aug 2026 07:33 AM
Wi-fi is repeatedly cutting out, no signal
then okay for a while, but same issues are
daily!!!!!
Message posted on 12 Aug 2026 07:39 AM
Re: Wi-fi issues are rubbish
Wi-Fi or broadband - they are different.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
