2
This discussion topic has been answered Discussion topic: Wi-fi down
This message was authored by: slaterose
Wi-fi down
Green lights on wall but hub has 2 green 1 orange and one blank. Wi-fi intermittent now down completely.
Avatar for slaterose
This message was authored by: slaterose Answer
Re: Wi-fi down
All good now! Thanks so much for your reply!
Re: Wi-fi down
@slaterose
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Re: Wi-fi down
