Discussion topic: Wi fi down
This message was authored by: Nordlux
Wi fi down
Really disruptive loss of broadband since 20th Nov.  Came back intermittently yesterday and this morning and now gone again. The unreliabiliy is crazy as I can't work. When will this be resolved! In SW16 area.
Re: Wi fi down
@Nordlux
We are customers and this is a customer ➡️ customer discussion forum where we try to help other Sky customers. I’m afraid you aren’t communicating with Sky by posting on here.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
▪️I AM NOT A SKY EMPLOYEE ▪️
