Discussion topic: Wi fi connection
Message posted on 20 Jun 2026 11:31 AM
Wi fi connection
My internet keeps dropping out. I need this for my remote work as a counsellor. I will need to change providers as this has been happening on and off for a week affecting my job.
Message posted on 20 Jun 2026 11:41 AM
Re: Wi fi connection
@Tray777
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
