Discussion topic: Wi-Fi
This message was authored by: Paul2311
Wi-Fi
Wifi not connecting
Re: Wi-Fi
@Paul2311
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
