Discussion topic: Wi-Fi router
Message posted on 07 Jan 2025 04:24 PM
Wi-Fi router
Does sky have a router with more than 2 output ports
Message posted on 07 Jan 2025 04:37 PM - last edited: 07 Jan 2025 04:39 PM
Re: Wi-Fi router
The 2016 Q Hub (now approaching obsolescence) has two ethernet ports.
Both the 2019 Sky Broadband Hub and the 2023 Max Hub have four ethernet ports.
Sky will be swapping out the remaining Q Hubs over the next year because they can't support Sky Talk Internet Calls and don't meet the new minimum standards for device security (specifically they have fixed weak local administrator credentials)
Message posted on 07 Jan 2025 06:15 PM
Re: Wi-Fi router
Thanks,
so do I just ask sky for a new hub?
Message posted on 07 Jan 2025 07:32 PM
Re: Wi-Fi router
They might be amenable to replacing a Q Hub with a Sky Broadband Hub if you agreed to a new minimum term, but will probably want to upsell you to a WiFi Max subscription.
