Discussion topic: Wi-Fi poor
Message posted on 01 Aug 2026 08:18 PM
Wi-Fi poor
The Wi-Fi has been dropping out more regularly and doesn't now reach the master bedroom. Resets only give temporary solution.
Message posted on 01 Aug 2026 08:26 PM
Re: Wi-Fi poor
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
