Discussion topic: Wi-Fi not working
Message posted on 24 May 2026 08:42 AM
Wi-Fi not working
Nothing will connect to my WiFi- it's notvworking
Message posted on 24 May 2026 09:30 AM
Re: Wi-Fi not working
@Lindsay33
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
