Discussion topic: Wi-Fi not working
This message was authored by: Nicolefearon
Wi-Fi not working
Need help with my board band as I cannot connect to Wi-Fi as my box is not working
Re: Wi-Fi not working
@Nicolefearon
In what way isn't the box working?
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
