Discussion topic: Wi-Fi not working
Message posted on 13 Nov 2025 08:46 PM
Wi-Fi not working
Wi-Fi not working Coming up no no connection right now,
Message posted on 13 Nov 2025 09:00 PM
Re: Wi-Fi not working
@Paul806
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
