5
This discussion topic has been answered Discussion topic: Wi-Fi not working
This message was authored by: Westys
Wi-Fi not working
My internet connection is not working I have tried numerous times to reconnect it
Avatar for Westys
This message was authored by: Westys Answer
Re: Wi-Fi not working
I pressed the question mark on my sky remote followed instructions then a telephone number came up I have an engineer coming tomorrow morning as I have a fault hope this helps
@Westys
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
This message was authored by: Angie40
Mine is same and i cant find a number to speak to a human
@Westys @Angie40
If you eventually need to call Sky dial 150 (free) from either your Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The forum filters don’t allow the posting of full phone numbers on here.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Avatar for Westys
This message was authored by: Adam299
Broadband not working. Red PON light on the fibre box?
