Discussion topic: Wi-Fi no working
Message posted on 11 May 2026 06:06 AM
Wi-Fi no working
Hi, my Sky Broadband WiFi has stopped working.
On my Sky SR203 router, the Power and WiFi lights are green, but the Broadband (or Internet) light and Voice light are orange/amber. Devices can’t get internet. I've tried power of and on cycle and all wire connections to the wall have been checked and look fine
Message posted on 11 May 2026 06:18 AM
Re: Wi-Fi no working
Mines the same woke up the internet test says it fine but it's just sitting on a green light no internet connection at all
Message posted on 11 May 2026 06:25 AM
Mine too (GU10)... woke up and again it's off.
Has been intermittent since yesterday afternoon. This is very frustrating 😞
Message posted on 11 May 2026 07:05 AM
@Marksteeluk @HRyan91 @Ziggie
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
