Discussion topic: Wi-Fi max makes no difference
Message posted on 23 Jun 2026 05:11 PM
Got a wifi max router as the signal strength in the living room is poor. The new router made no difference so £6 a month wasted.
Message posted on 23 Jun 2026 05:32 PM
Re: Wi-Fi max makes no difference
It's the WiFi Max subscription supplement which facilities the loan of wireless booster 'pods'. By itself the Max Hub isn't permitted to be more powerful than any other such hardware.
Message posted on 23 Jun 2026 05:49 PM
The £6 you are paying is for an extra service called WiFi max under which Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
