Discussion topic: Wi Fi keeps failing on my wifes diabetic equipment
This message was authored by: Row0-_
My wife has a Freestyle Libre  Link, she is having big problems wit it it keeps loosing the WiFi signal in doors she stands next to the router and it takes ages for it to connect to the WiFi  and if she goes into the garden in about two minutes it signal is lost again. Any help would be appreciated.
Re: Wi Fi keeps failing on my wifes diabetic equipment
@Row0-_ not knowledgeable about this kit which. I beieve uses Bluetooth connection between the sensor and the app on the phone. Is your wife's issue the link between the sensor and the app or the phone losing wifi connectivity?. If the second no apps on the phone would work. See https://www.freestyle.abbott/uk-en/support/tutorialsanddownloads/troubleshooting-guide.html
Bluetooth typically has a maximum range on 10m or so which means she needs to be close to the phone rather than the Sky hub indeed given bluetooth and WiFi use similar wireless frequencies being close the hub could cause issues with the link between thecsensor and the phone.
