3
This discussion topic has been answered Discussion topic: Wi-Fi keeps dropping out
This message was authored by: Lisa1130
Hi - my sky Wi-Fi boardband keeps dropping in ans out and has been all afternoon I've reset the Wi-Fi 4 times by unplugging etc. thanks
Re: Wi-Fi keeps dropping out
@Lisa1130
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again later).
@Lisa1130
This message was authored by: Harry22222
Faulty booster that I paid for
@Harry22222 Have you called sky then, they are open until 8pm this evening, and from 8am - 8pm every day apart from ROI at the weekend, they are closed then!
