Discussion topic: Wi-Fi keeps dropping out
This message was authored by: Kerri19
The broadband keeps dropping out when watching something or kids are gaming
Re: Wi-Fi keeps dropping out
@Kerri19 assuming the leds on the Sky hub dont change when you lose connection the most likely issue is poor wifi signal. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
