Discussion topic: Wi-Fi issues
Message posted on 05 Jan 2026 10:46 PM
Wi-Fi issues
Wi-Fi only works in 2 rooms, doesn't work in kitchen or kids room. Been disconnecting me all day every day for past nearly week. Going to give sky a call tomo for a booster and to sort this problem, if not will be changing to talk talk Wi-Fi as only £20 or less for Wi-Fi on it own .
Message posted on 05 Jan 2026 10:57 PM
Re: Wi-Fi issues
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 05 Jan 2026 11:23 PM
Re: Wi-Fi issues
@AMS20x As long as you are not in contract you can do as you want, but a sky Max booster is an additional £10/month to get so good luck with it all, and you do need to call to get one for sure, no other way!
