Discussion topic: Wi-Fi issues
Message posted on 29 Dec 2024 09:19 AM
Wi-Fi issues
Okay so I've never really had any issues with my Wi-Fi. Then last night the light on my broadband box went red and hasn't changed since (around 4am).
Called Sky they gave me suggestions such as:
Reset
Unplug and plug back in
Change Outlet
And the light is still red.
What do I do?
Message posted on 29 Dec 2024 09:44 AM
Re: Wi-Fi issues
@AbbieLouise if the Service Checker does not tell you thst Sky are aware of a fault with your line call them and report the fault so they can get it fixed.
Message posted on 29 Dec 2024 10:08 AM
Re: Wi-Fi issues
Says there's an issue connecting to my hub. And that there's an engineer investigating. Not sure what that means.
