31 Mar 2023 10:33 AM
Hi,
every time I take my phone or iPad upstairs, the only way to connect to Wi-Fi is by disconnecting Wi-Fi then turning back on, once it's connected it stays connected, Wi-Fi speed upstairs as as fast as downstairs, it's just the annoying need to turn off then back on.
anyone have any ideas please?
thanks.
31 Mar 2023 12:23 PM
Posted by a Superuser, not a Sky employee. Find out more@nickykane Are you having to turn off the device or are you saying you have to turn off the router to get it to work?
31 Mar 2023 12:44 PM
@Highlinder wrote:@nickykane Are you having to turn off the device or are you saying you have to turn off the router to get it to work?
I think the Wi-Fi on the device(s) is being turned off then on again, then the device(s) connect to the Wi-Fi.
@nickykane - do you have any boosters, AP's or a Mesh system in place?
